As far as i can tell there is no way to get the current screen index in code in klwp.
Hi! You can use $si(screen)$
to get the current screen you are in.
thank you, also, this should be added in documentation.
Its documented inside the app but not on the website since its something on KLWP only, will check if i can add it there too, thanks!
