How can I display multiple alarms?
I would like to display the next alarm and also the alarm after that all in the same widget. Is there a way to do this?
Thanks,
Danny
I think that you can't make this in Klwp. Klwp take the notifications from the notification panel of your phone, and the clock notifications appear (in my phone, and I think that in every phone is quite similar) 2 hours before it's set. Klwp don't have access to other notifications different than this.
Hi Danny excuse me, my bad, you have the option in the si codes to show your alarm. I think that you have the only option to show your first alarm, I tried all possible codes with no luck to show other alarms.👍
