Help with shifting text
I have been using kwgt years and now have a problem. See pics at link below. I use tasker to set up the widget text, etc. After a while the text shifts to the left. If I look at the kwgt setup, the position hasn’t changed nor has the left, right, center changing. Can anyone help?
Guess i have version 3.77 of kwgt, android ver is 14.
https://imgur.com/a/Oq6qMzk
Based on your screenshot, it looks like there’s a Stack Group element in the widget that its left part is hidden from the display.
Suggestion:
Check the Display status of the Stack Group element, that wrap those shifted Text elements, to find out what condition make it hidden (the display status is set to: Remove).
I’m sorta new at this so I’m not sure what you mean. The lines of text aren’t grouped in any way in the kwgt setup. Each line of text comes over from Tasker as a separate kwgt variable.
Thanx
Also, i ran the tasker task to set it up properly and then disabled tasker. The text hasn’t shifted since. So I think it has to be tasker. But I can’t see that tasker does anything to these variables unless I manually start it. So it doesn’t make sense to me,.
