Hello, is there a way to do a negative version of "~=" ?
Since Kustom does not have a separate weather code for Mostly Clear/Mostly Sunny it just assigns it to "CLEAR." However, I have icons for Mostly that I want to use.
My workaround is to check if the weather code is "CLEAR" and the weather condition contains the word "Mostly" then use the icons for "Mostly Sunny" and "Mostly Clear."
wi(code)=CLEAR & wi(cond)~=Mostly, (if(ai(isday) | gv(nightico)=0, gv(msun), gv(mclear)))
Got that part working but having trouble defining if the weather code is "CLEAR" and the weather condition does NOT contain the word "Mostly" then use the icons for "Sunny" and "Clear."
My reasoning for not using "gv(cond)!=Mostly Clear" is that some weather sources use "Clear" for both night and day but other use "Sunny" for day and "Clear" for night.
Any help would be greatly appreciated.
