Help w/nfc state using tasker
I'm trying to create my own quick settings panel, including the nfc tile, where the color changes depending on on the state, kustom doesn't monitor the state of nfc but tasker can, unfortunately I'm brand new to tasker and can't figure out how to get it to 1. Monitor the nfc state(enabled or disabled) 2.then send it as a variable to klwp. I could really use some kustom/tasker wisdom
