Help - Touch No Longer Works
I have a custom widget I have used for a long time. It has touch set up on various items in the widget. Today, they all stopped working. Instead, when I tap on the items, the widget editor launches.
Help!
In the editor, go to the root folder >> Touch tab >> Remove “Kustom Action => Advanced Editor”.
I did that. It seems like just the text displaying time doesn’t like to play well with the touch settings.
The app did some other weird stuff, but nothing I want to report yet. I am trying to see if I can reproduce it.
If this issue affects only some elements, it might be a design problem. Ensure the touch functions are assigned to the correct elements and are not obstructed by other elements.
