I think that your moon komponent aren't going to work, I put other moon komponent and solved the alarm. Test it and see how it work.
https://drive.google.com/open?id=1eL-xn_D8oUJ_axd89owmVVflvuhOkapw
By cons I tried to understand for the alarm my mistake and I can not :(
You made magic that's it? : P
Because the only difference I see is the display of the box that changes from "always" to "never" but me when I try it does not change state.
I did not understand the usefulness of "Moon Prases (Drawing)"
Sorry to ask all these questions, I try to understand and I only have notions.
Really, thank you
Merci beaucoup c'est vraiment sympa.
Par contre j'ai essayé de comprendre pour l'alarme mon erreur et je n'y arrive pas :(
Vous faite de la magie c'est ça ? :P
Car la seul différence que je vois c'est l'affichage du caque qui change de "toujours" à "jamais" mais moi lorsque j'essaie il ne change pas d'état.
Je n'ai pas compris l'utilité de "Moon Prases (Drawing)"
Désolé de poser toutes ces questions, j'essaie de comprendrez et je n'ai que des notions.
Vraiment Merci
I put the formula of alarm in the visibility of the layer, if the alarm is on,always, if not, never(visible).
The Drawing is a draw of the moon, you can change it to draw in the globals and see the difference, after this you can change to image if you want.
