Try to see iif you can load an old preset in the restore in the editor the clock icon. If you don't have luck with this, in the menu(three lines in the top left of the editor) you have in the settings the option with the user login with your Google account to unlock the preset locked. You need to load the preset and use this option to unlock the preset. I reccomend you to go with the first option first.
When you export a preset don't tick the onlyread, because this lock the preset.
Thank you
Thank you
De nada, espero que hayas resuelto el problema.👍😃👌
