I currently have a set up in which I'd like to be able to switch to a view with a text field showing me the current speed using $li(spd)$. All permissions are set correctly and I have tried using the high update-frequency, all without success. What else can I try?
In your subject you say that location is 0, is it location or just speed? Are you on KWGT or KLWP? Did you try to set the location accuracy to max level in the settings?
I'm having the same issue. Please see my new post. Tags: Location, not working, gps, speed
Screen shots included.
