Globals going crazy
When I change a global (non switch type) all switchs goes on or off...
I cannot reproduce this, i add a switch, turn it on, add a color global, edit the color, switch still on, add a list global, still on, edit the list global than save it and switch is still on.
Try out with the calendar komp :)
I think there might be an issue when there is a huge number of Globals and then for memory reason some of the views gets somehow swapped out, not sure, this is very hard to reproduce
