Ghost widget
Long time ago I had created a widget. One day I lost it somehow and now I have no idea how to delete it or where is it in my phone. I’ve searched everywhere without luck
It’s the first one
KWGT gets widget list from the system, so if the widget is reported by the system it could be:
  • On a different launcher than the one you are using
  • Gone but not removed properly by the launcher
Unfortunately KWGT cannot delete a widget from the system, the only solution if you cannot find where it is is exporting your existing widget via Preset → Export, uninstall KWGT, reinstall and then add the widget again and import.
It worked. Thanks a lot
