I've tried all manner of ways to do this, but success in getting it onto my home screen is a "VERY" hit-or-miss proposition. Tried on three difference devices; all with same result.
If you can explain a bit how you want to change the walls, maybe are a possibility to help you.
In advance is very ease by time, every n minutes, by example.
Thank you. I'm not trying to change it "on the fly".
Simply, I load a wall (load preset) into the editor. Make a modification. Export and save.
Now to get this to become the wall paper on my home page is a real hassle. After trying several different ways, I can SOMETIMES get the wallpaper set as my new wallpaper. Most times the old wallpaper just stays and is not replaced by the new one.
I'm sure I'm doing something wrong. It should be so simple; maybe I'm just dumb.
Thanks for you help.
First of all, if you don't know something, you are not dumb, you don't know something, no more than this๐๐
I think that you want to change an image wallpaper, and not is this.
For load a preset, you need to tap in the disquette icon in the top of the editor, every time that you tap in the disquette, this is the preset that you have in your screen when you go away of the editor. If this is not working, maybe is a problem with your phone OS, or other.
Nelson, it was indeed as easy as pressing the disk icon. However, it seems from experimenting around that there may be several other ways to do it, but none of them work. Hence my confusion.
Thanks SO MUCH for your help.
Ohh yes, the only way that works always is the disk icon๐๐
