Function nc(aname) not working properly.
The function to get the name of a connected Bluetooth device is not working. I can get the nc(aname, 0) device, my LG V40 (LM-V405 using Android 10; V405TA30c; June 1, 2020 update), but get nothing when using the 1,2,3,4,etc variables.
I've tried for 6 hours to get Tasker to pass this information, but it doesn't reliably work without being manually refreshed. Please, please fix this if you can!
Also, do you still plan to add Bluetooth battery level as well?
... crickets...
O asus 5 z tem o mesmo problema
