Formula to have animation react on every minute?
I know I can set a timer to turn on a switch every minute but I'm looking for a way to have an animation move forward every minute change of the actual clock
Go to the item you want to animate, React on formula, $if(df(s)=0,f)$
Thank you. This does work, however, the animation is longer than 1 second so as soon as the (s) changes to 1, the animation moves back to start (default "else" is 0 if not specified)
