Forced to use alphanumeric keyboard in KLWP
I am a Japanese speaker.
In text input within the KLWP app, Gboard is locked into alphanumeric input mode and I cannot type Japanese characters; similarly with other Japanese IMEs such as ATOK, I can only type alphanumeric characters within KLWP.
When copy-pasting from other apps or using voice input, I was able to type and display non-alphanumeric characters.
Anywhere in the app or only in the main editor? For instance in the settings when you search a location is it any different? This is the first time this has been reported afaik
Sorry for my ambiguous description.
It seems to happen only on Formula Editor.
I was able to enter Japanese when searching location and exporting a component.
The language of the application is set to Japanese.
My device is a Sony Xperia 1 II with Android 12.
If there is anything else I should tell you about my environment, please let me know.
Thank you for your support.
This is fixed in 3.75b407209
Its available via manual download at
Now I can use kanji in Formula Editor!
Thank you very much💖
Thats great, thanks for confirming its fixed and thanks for reporting it!
