forcast not available
why dont working wheather forcast?
That means that forecast has not been properly downloaded yet, you can try the following:
  • Go in the app settings, press the "Force Weather Update" option and check if both location and weather are detected properly
  • If Location is not correctly found ensure that either GPS or Network location are enabled on your device, as an alternative you can set a fixed location in the options too
  • Once location is detected, if weather is still not ok please try a different weather source, there should be 4 in the options, if you still have issues generate a debug dump (the last setting option) just after a force update and email me the result at [email protected] mentioning this thread
