Fonts not always displaying
Hi. I've had this problem since the last update, approximately early June 2022.
Samsung tablet-A, SM-290, Android11
The fonts do not always display properly. See attached screenshot. Some of these fonts are wingdings and should show up as flowers, seashells, weather, etc. The truly "text" elements are the same fonts I have always used. Apparently Roboto or some other default font is all that shows up. I also attached a screenshot to show you Internal storage/Kustom/fonts.
Other wp elements such as images & components work fine. I have un/re installed, rebuilt wp from scratch & un/re installed font folder and it keeps happening. I have 5 different wallpapers I alternate between and it is happening on all of them.
Any ideas? Thank You
