I've been searching this problem for 15 minutes and found no solution, maybe i didn't search far enough.
Then i tried something, i tried to set 2 text variable with flow, Text A is outside a folder and Text B is inside a folder. Both Set Global Var action i put under Formula action with "1" value, this should set both text to "1". After i trigger the flow, the result is Text A value become "1" while Text B value remain blank, this is where im very sure that this is a problem.
I know i can simply just put the text outside a folder but i want to make it tidy by putting it inside a folder. But i'll do it for now since there's no solution for it so far.
Let me know if there's a solution to this if this is not a problem and im sorry if its hard for you to understand what im saying because English is not my main language.
