Hi all
Sounds delay is not working using Flow
I’m now on klwp
I tried to manually trigger a Flow which contain a Delay action. It works well on my homescreen.
So it’s same I did but not working for me
There is not delay applied
Perhaps it would be better if your post here is moved to Issues category.
Done
Is there a way to send more infos
Sorry my bad , I assigned the flow to the wrong object
So… does the delay action function well then?
Yes all fine …
I just did a mistake
