Flow Action Intent URI
Samsung galaxy s22 ultra
Model - sm-s908u1
Android version - 13
Trying to implement the following flow action:
Url: autotoolscommand://curprs=:=$wi(press)$
Will only work if I am in the editor when the CRON triggers the action. Otherwise nothing seems to happen.
Was wondering if it could be a launcher problem?
Check and make sure that all required permissions are set to always instead of “when using the app”.
