I'm trying to use the Fade Out animation to work for a Background Blur Mask but once I apply the animation to any Komponent it makes the whole thing dissapear. I tried it on Shapes and Images with and without the Background Blur Mask. It does work if I use other animations.
Not sure i understand, you have a fade animation applied to a komponent and that affects a shape with a mask set to blur background and the blur background doesnt work when you use the fade?
