Hello,
Would it be possible to have an example to display and hide buttons (* .bmp) as on the image for KWGT ?
Please, that would be really nice.
Maybe this video tutorial from Brandon Craft can help you
Thanks for the video link
I just watch the video and so it is possible but under KLWP and not in Widget KWGT if I understood because I can not find the same command.
After I do not understand English so a little more difficult.
Otherwise I'm here:
https://drive.google.com/open?id=1rerwbeTAjCCoY0u6JEAVone_QmqjVQIC
To hide buttons in Kwgt you need to put the buttons inside an overlap group and try to use the visibility of the layer of the Overlap group, I put this videos because is a good option, you need to figure out how to make this work in Kwgt, like I said using the visibility of the layer
Layer>Visibility,
here you need to use the formulas to make the Overlaps group visible (always, never)
It's so much easier to learn by disassembling :)
I do not understand what he says and just looking at it I do not have enough information: S
I'm done but impossible that it works.
I searched everywhere on the internet and I did not see a single KWGT Widget with this function to try to help me.
Would a charitable soul be ready to help me for this little piece of code?
Promised after I will not ask for anything, besides I think it will not help me.
Test this and see if is what you want
https://drive.google.com/open?id=1EhjXJGxblYKeSmfLV2PNqLmzPgTrO3Yk
Perfect is exactly what I needed as an example. Thank you very much for your help once again.
๐๐๐
