Error with screen unlock
When I lower the notification bar from the lock view (created with klck) and click on a notification, it opens the application, but the lock view is still visible. I consider that this should be removed when another application is opened. Here is a somewhat accelerated use, first from the notification bar I open the first one, however, until I double tap the lock view (event that I use to unlock) at that moment I can see my notification
Screen_Recording_20240707_024937_Smart Launcher_1_1
dispositivo : samsung A34.
version klck: 3.76b418415
KLCK is meant to render on top of other apps. You will have to swipe out KLCK to be able to see the apps behind it.
