Error: Attempt to invoke virtual method 'boolean' < Need help please!
Hi there, I see many other questions to this but so far I don't see
the answer to solving it?
Anyway I get this Error on my "Wico Android Phone", I also have a Moto
Android phone and don't get this error!
Any help? thanks!
The preset you are trying to load is loading preset directly in editor window for you using org.kustom.lib.wpaadvance editor method it is causing this problem and system doesnot recognize the package uri if u are a user u can't do anything about it but the wallpaper developer should have used org.kustom.app.LoaderActivity to navigate user to kustom dashboard using third party app or his own dashboard
