Description: be able to dynamically add objects from klwp within klwp using a new "dynamic group".
Example Applist:
Get an a list of apps as a string (either from Tasker or klwp shell) add a dynamic formula: for each in string -> duplicate content of dynamic group. The dynamic group contains shapes icons etc. Iteration is done over the contents allowing you to dynamically add them. Settings are changed by having a predefined variable as an iteration string.
