Doesn't work
Hi,
The last beta update broke my klwp presets. To be precise it worked well until I change the wallpaper with the phone settings to try something, and when I re apply the klwp wallpaper, all was broken. The scrolling doesn't work anymore. The different elements are scattered anywhere.
I clear data, uninstall and reinstall the app, but it won't work anymore.
Can I have access to the previous version ?
Please help me. I'm on Huawei mate 20 pro with nova launcher.
Gael
Here you have all the previous versions, download it to your phone, uninstall your actual version(before make a backup of your Kustom folder in your phone, this is not needed, but for security😁) and reinstall the old version.
https://rink.hockeyapp.net/apps/841d1a9421b54e9e40f8fcf2666afd66
