I install the themes well and they work but when I turn off the screen and then unlock it disappears the image of the theme is no longer applied and I have to apply it again.
This means that something on your device is either killing Kustom service, applying another wallpaper or your launcher has issues
And how to know which application or which is stopping the services of klwp, I already tried other launcher and I still do the same or it will be my cell phone that does not allow it.
I dont know, hard to tell, do you have any memory cleaning app? Or does your phone has a specific white list for background services?
I already worked correctly thanks to your help, I thank you very much and if my phone had an application cleaner in the background, I turned it off and it works perfectly. Thank you for your time, help and for having responded.
Which app it was? Just for reference
It is the same phone that brings that option in the configurations, since I have a P9000 elephone and there is the option of Background task clear, all I did was disable it and everything was working properly. Thanks again for your help.
