Does klwp support Player Pro?
I tried force linking it too from the klwp settings to choose default player. But still the widget player on the home screen doesn't respond to it. The cover art won't show, track info doesn't show either. Only thing working is the next and previous buttons. Also when i press the play button the pause button doesn't show. Everything works when i play using the default phone music player. But I'm using Player Pro n all my tracks are updated by the app too. So any idea why player pro doesn't work well in klwp?? Please help me. This is a major problem for me right now.
Thanks
Unfortunately Music cover and controls depends on the player not on Kustom which just uses standard Android controls. You need to get in touch with the player devs and ask them to properly implement the MediaManager interfaces.
apple xac thuc hai yeu to
