Delay features in touch actions and formulas
Hi there. What about a "delay" or "wait" function in touch menu, where you can set a delay after the tap before performing the action.
Also it would be interesting to add it as a function in formulas. For example
$if(a=1,#FFFFFFFF, delay(1, #FF000000))$
meaning that after the condition is met (a different than 1), color will wait 1 second to switch from #FFFFFFFF to #FF000000.
After only 6 years 😅 this now can be done with Flows in version 3.70, to do this you need to:
- Create a new Flow
- Add a formula trigger $a = 1$ set "trigger when not 0"
- In the actions add a delay action
- Then add a set global action to set your X global to the color you need
