Hey guy, I just installed the Dazzle UI theme, but when I set it as my wallpaper, the animation to change the wallpaper works, but the calendar sliding to the left doesn’t work. Do you know the solution?"
“And the remaining icons don’t appear, they show up at the bottom like they’re glitchy.”
I don’t know the Dazzle theme, but it sounds like you need more pages or screens to display it. That will depend as well on your launcher supporting multiple pages. Check the top right corner area of your Kustom interface and you should see a little TV icon with something like 1/3 in it. This means you’re on page one of 3. So you would need to set your launcher to have 3 pages. Most, but not all, support horizontal pages, and a few are supposed to support vertical pages. Just a possibility for your problem.
“It worked perfectly! That was the error. Apparently, without having pages on the desktop, the theme couldn’t move correctly. I created about 4-5 pages and it was resolved. Thanks!”
