Is there a way to crop text?
like if the word is 7 letters long.
Have it crop to 4 or 3 letters only.
Thank you
Thank you
Hi Alfred! Sure! This is possible using the TC function, these are the examples provided in the app:
You can both use "ell" and "cut" with the same parameters, the difference is that "ell" will also add 3 dots at the end when cropping the text. Off course "some text" can be replaced with anything, also functions, so, to show first 2 chars of the month name you can use $tc(cut, df(MMMM), 2)$
Hi, wondering if there is any way to use the same formula but instead of counting the character it would look at the total length.
Maybe if you plug in a formula instead of the number?
