I have an array containing numeric values (steps data for past 30 days). Is there an option to count number of instances in the array exceeding a value. i.e. number of values above 10,000.
Kustom supports loops via fl()
fl(
[start i], [end i], [next i value formula string],
[iteration formula string],
[optional separator]
The loop starts with i
being equal to [start i]
and runs until i
is equal to [end i]
. Every iteration consists of calculating the result of the [iteration formula string]
, setting i
to the result of [next i value formula string]
and checking if the end condition is met (either i
= [end i]
or maximum number of iterations exceeded).
The iteration results are concatenated together, if the [optional separator]
is provided, it is inserted between each iteration result.
Formula strings passed to fl()
don’t need the $
, those are appended automatically under the hood. Any string literal i
within the formula string will be replaced with the current value of i
(the i
in split
won’t be replaced).
Let’s say your data has 30 entries. The solution could look like this:
$tc(len, fl(
0, 29, "i + 1",
"if(fd(steps, r + i + d) > 10000, a)"
Each iteration will return a
if the number of steps for i
days ago is greater than 10000
, empty string otherwise. By then measuring the length of the result with tc(len)
, we get how many iterations found a value greater than 10000.
Thank you. Got it working.
