Copying and pasting globals in folders for better organization
Copying and pasting globals doesn’t work inside or outside of folders, if I try to copy say a text variable for the globals root and paste inside a folder, it initially appears, but if I return to the folder later, it’s gone, also, if I copy a folder from klwp with variables inside and try to paste it into a komponent, it only pastes the folder, it would sure be nice if this worked and with a folder of the config I want in a komponent to match the overall theme, you could just declare the komponent global folder to follow the main globals, using the globe icon, of course.
I just started using this and as sophisticated as it is and what it allows you to do, it’s amazing, but I’m surprised that common text/code handling options like this are missing. They may be there but not as obviously as they should be. If they are . . .
I’d like to be able to take a selected batch of items and put them into one of the containers consolidating items or moving them around to reorganize. And like you’re trying to do copy and paste settings to individual items, into a Global Settings or wherever else they could go and be properly placed in the appropriate fields.
