Constantly crashing
Recently no matter which preset use after a while my wallpaper is back to standard wallpaper. Not sure if related to latest update to November security fix on android 8 running on pixel XL 128gb with Nova launcher. Stock ROM not unlocked.
Please reproduce the issue then follow the steps at https://kustom.rocks/debug to send me a bug report
Sent of the bug report, just hope done correctly.
Hi, I've done some further testing and found had same issue using apex launcher, so tried stock and that was fine.
Removed Nova, rebooted, reinstalled and so far seems to be working, bit will continue to monitor it.
You did, thanks
