Conditional launching commands
Hi,
I'd like a new feature: launch a command only if a given formula is true.
That is, each touch action can be linked to a formula that is evaluated before the launch and if true the action runs otherwise the action is skipped.
Thanks
I was thinking the same, but basically you will have exactly the same result by putting the touch action on an invisible square. Then you write down the formula in the visibility option, and your output will be Always when the action is to be performed, and Remove when not.
Then you can add as many squares as the conditional touch actions are.
