Lo he intentado de todas las formas posibles pero no lo entiendo
The problem is after an amount of time starting from when? From screen unlock? From a specific date? After a while since a button is clicked?
Es para que desaparezca a cierta hora
Ok, so, if you want to have a text or an image or anything to disappear at a specific time you have to do this:
- Create an Overlap Group
- Add your text, your image whatever you want to disappear
- Go in the Overlap Group, go to the Layer Tab, select the Visibility option, turn it into a formula (by pressing the "calculator" icon
- Now your visibility is a formula, you can either return "ALWAYS" to make it visible and "NEVER" to make it didisappear, a few example of using that might be
- $if(df(H) > 16, NEVER, ALWAYS)$ to make it disappear after 5 PM every day
- $if(df(S) > df(S, 6M1d0h0m), ALWAYS, NEVER)$ to make it disappear every year after the 6th of June
Hope it helps
