Clock wrong on Wallpaper only
The clock seems to display the correct time in the preview (matching the system clock), but when applied it's off by 5 hours. I've never seen this before and am a bit baffled. The location is already set to my zip code, evidenced by the weather being correct.
You're not alone. Mine is doing the same as of the last couple days. 4 hours off for me. But shows right in tbe app when editing my preset. Seems it's showing GMT instead of the correct timezone.
Until it's fixed I change the formula to $df(hh:mm, r4h)$
Thanks, hopefully it's patched soon
