If you set a shape mask to a clip, that is inside an overlap group the padding under position does not work correctly anymore.
For example if you make a square anchored in the center and give it 50 padding from all directions than the square stays in the perfect center as it should, but if you than make it into a clipping mask it moves to the top left corner of the area designated by the padding (refer to attached screenshots).
