Clipping objects KLWPand KWGT
When I put two objects in a Overlap Group and use the XPadding positions, all goes well.
When I set an object to clip the next/all item(s), the paddings always go to the same side (top/left).
If I add padding to bottom, it goes up (like it should), but when I add padding to the top, it goes to up as well (but shouldn't).
I attached a sample komponent
