Clipping module FX bug
Clipping never seems to correctly display the shape in the editor. Examples in the attachments. If I remove the clipping effect, the shape shows correctly in the editor.
Specifically the preview window does not respect an object's rotation. For example a rotated triangle shape will display correctly, but return to its zero rotation position in the preview window when used as a clipping mask. However when view on the home screen it is as intended.
