Clipping a circle, strange behavior
Upload of images here: https://imgur.com/a/b2IvlEv
I’m trying to clip a circle in a top part and a bottom part. I’ve made two circles in the same spot and two rectangles, one on top, one at the bottom (see 1st image).
When I clip (clip next module) the 1st circle with the top rectangle that works as expected (see 2nd image).
When I try to clip (clip next module) the 2nd circle with the bottom rectangle (see 3rd image) it does the clipping action, but the result ends up being at the top of the circle (see 4th image).
Any idea as to why? And how to fix this?
I’ve already checked if it’s a graphical glitch, but that doesn’t seems to be the case.
And I know I can use Clear instead of Clip, but sometimes you want to use Clip, so I still want to know why this happens.
If anyone’s willing to look at it, here’s a Komponent with this behavior: https://file.io/4Q0SZsuqCp3K
