Clip in Overlap group with animation made the padding be one directional
So I was trying to animate something. I was working in the editor. I got everything aligned. I basically had an image with shape in an overlap group and I was trying to clip. In the editor everything looked alright but then after saving I was getting off-center clip. Aside from the fact that I would see one thing in the editor and a different one on the wallpaper home screen, the padding for the clip shape was only allowing for padding in one direction
I don't know if this is a kniwn issue or not but I figured I'd let you know.
Thanks,
Andrei
Can you provide a simple example to reproduce this? So you mean padding in clip is not applied?
https://drive.google.com/file/d/0B6ggTVWI0PiMV1VXSHZKaXRyTzA/view?usp=drivesdk
I've tried to work around it. I made a komponent instead of overlap group. It still had the same issue. The way around it was to find the alignment which allowed for padding in the direction I wanted. So to move my clip from the centre let's say by 200 in both x and y, I would need to do alignment bottom left screen and add lots of padding. You will see in the komponent called MainTrLand and MedTrLand.
https://drive.google.com/file/d/0B6ggTVWI0PiMNlM5TWZiZ0Y2T2s/view?usp=drivesdk
Here you see how the editor show one thing and the wall another
I replied to myself rather than this msg. The screen shots are above
Hi Frank
There are 5 or more queries about this problem on this page and I have one in the Kustom community on Google+.
Is there any answer?
