Ciao come posso impostare l orologio alla schermata di blocco
Hi Giuseppe, if you can write in english is best(I'm spanish🤣😂) using the translator I think that you want to add a clock widget to your lockscreen, yes? To this you need that your lockscreen allow to put widgets in it. I think that few phones have this option (Samsung s8 and 9 if the Good Lock app is installed and work like in the past.). I think that you can not add widgets to your lockscreen.🤷♂️👍
