charging dot, point
Hi guys,
would like to create a dot how only shows up when the phone is plugged in & charging.
Is this possible? Thx
Sure! Just do the following:
  • Add a Shape Module
  • Set the Shape to a Circle, make it a dot of some sort
  • In the Paint tab, select the "Color" option then press the "Calculator" icon on top, this will turn the paint into a formula
  • Use this formula $if(bi(charging) = 0, #FF00FF00, #00000000)$ then replace "FF00FF00" with the color your want, this will make the shape transparent when not charging and use your color when charging
Thanks a lot
