OK all - Looking for some guidance. I'm trying to create a TEXT object for temperature and would like to change the text color based on the temperature value.
I've got what I thought should work using:
$IF(wi(temp) > 85), [c=#FF0000]wi(temp) + "*" + wi(tempu)[/c], (wi(temp) > 50), ..........
You get the idea. But, this isn't working. I get no text instead of a changing text colors based on temperature range.
Is there an easier way? A better way that I'm not considering?
thanks!
