The path of my images for my background seems not detected as I type it in the formula. I am using S8+. It works for global though. I did a lot of variations in the path and still not working and nothing appear in the screen. I used:
What is "selected pics"? What are you trying to change? If you want to access SD images you need to write something like "/sdcard/path/image" but you need to first check that the image is in your SD card.
I am trying to have a wallpaper changing base on every minute or every hour, but as I type the path of my first image by pressing the calculator button, the image does not appear...Yes..my images are stored on that path I copied both in SD Card and Phone Storage..Selected Pics is the folder where my images are.Is there something wrong with my synthax, or some kind of setting to do?
I did that and other variations, I even tried with quotation marks, but the image wont appear. But if I try to Pick an Image, it loads up with a global path. why it cant access local path?
