Changed my Huawei font by replacing the DroidSansChinese.ttf file and now it overwrites KWGT fonts, any help?
Recently I changed my Huawei device's system font which requires the user to replace a file named 'DroidSansChinese.ttf' with thendesired font under the same name.
By doing that it forces my KWGT Widget to use the new system font and I have no idea if there's anyway to make sure KWGT still uses the widget font instead of the system font.
My device is a Huawei P8 Lite 2017 running Emui 5.0.1 if that helps. Thanks :)
Change the font in the KWGT file.
