Is it possible to change the visibiity of a layer / komponent etc based on a Tasker Variable?
- I have a set of media player controls I'd like to see only if I am at home. I can set this using Tasker to check a combination of being connected to home wifi / cell tower location or GPS but cannot see how to incorporate it into the visibilty in KLWP?
Add to Tasker a KLWP/KWGT send variable plugin, set Kustom variable name to "media" for example and lets assume value will be 1 when media should be visible and 0 when not (this needs to be done in Tasker somehow)
In Kustom go to the Layer or Komponent you want to see / hide, go to the "Layer" tab, select the visibility option and turn it into a formula by clicking the calculator icon on top
Use a formula like "$if(br(tasker, media), ALWAYS, NEVER)$"
Done
P.S. you can potentially do this also in native Kustom Kode by using $li(lplat)$ / $li(lplon)$ and assuming you know your GPS coords
I wasn't seeing the calculator icon and so couldn't figure how to set visibility on custom formula. I initially had the variable called home and it wasn't working but when I changed it to media it worked great.
