Can't export preset
I'm on the latest beta (3.61...711, android 10. When I try to export my preset I get a warning: Duplicate entry: icons/ entypo.tff. Only option is to click "ok". After that the progress spinner keeps going, but the preset doesn't get exported.
Tried removing entypo.tff from Kustom, but that didn't change a thing
We don't seem to be getting and help here. I'm having the same issue
same issue, no help 😵
I believe there was a change in handling iconfonts by the developer in version 3.60. The method before and after don't match very well. If you have iconfonts from before and after you'll get this error. The solution is to reset all the old ones. If you go to your iconfont the first option you have is "SET". Material, Entypo, Fontawesome, Meteo are the e standard choices you get. Simply tab on that and pick the same set. So material for material, entypo for entypo etc. This should do the trick, unless you are like me and missed one the first time 🙂
Hello, what do you mean with "SET"? I've got the same issue but don't know how to reset.
In the preset there will be at least two fonticons. When you click on one of them the very first option you get is to choose a set. It will probably be Material, Entypo, Meteo or Fontawesome. Click on that and choose the same set as it was on. Do the same for all fonticons
