So recently I factory reset (system, data, cache, dalvik cache) my phone and like usual downloaded klwp and kwgt. Upon trying to open both all I got was a blank screen. Here is a logcat.
This is caused by opengapps incompatibility with Android support libs in use in Kustom, this should be fixed in the next beta i have uploaded for manual download here:
#KLWP http://kustom.rocks/klwp/apk
#KWGT http://kustom.rocks/kwgt/apk
Please confirm if that works
Ah I see thanks for the quick reply. And yes those two apks did the trick. Thanks again.
Thanks for confirming, marking as solved, will release soon
